toledo2525
IN THE ATTACHED PROJECT, I WANT TO INCLINE THE S4 COLUMN. THE COLUMN WITH 20 DEGREES ANGLE DOES NOT ATTACH ADDITIONAL REINFORCEMENT TO THE COMBINATION ZONES OF THE COLUMN. THANKS.
Hello, you can do it with a polygon column. 1. Create a closed area in the size of the column with the line command. 2. Curl the column in the column settings. 3. Convert the lines into a polygon column with the convert polygon to column command. 4. Rotate the resulting polygon column 5. Then define the beam. The sample project is attached. It is also explained in the following link:"OZGE":26donuqy" said:HELLO I'm having trouble making an inclined column in the program, it's difficult to bend the column in both x and y directions, I'm doing the others, but I couldn't do this in this project, I would appreciate if you could help with this. Also, I would appreciate if you enlighten me on how we should bend the beam when we bend the column Good work
