In the column polygon
tugce
hello, I made a U-column polygon around the elevator in my project, but I can't close the opening with the slab edge and I can't throw my slab, what should I do? urgent help please..
I need to use a panel to turn with a curtain, but when I use a panel, I create a U with a combination of 3 separate panels. is there any other way i can do this as full polygon?
You will solve it with three curtains anyway. When you make the elevator curtain a Polygon column, you define a bar element and you enter data against the logic of the program.
I understood, so when I make 3 separate panels, should I close the opening with the floor edge or with a crease?
If you wish, you can close it with a beam or with a slab edge. Of course it would be better to use beams if it is actually going to be personified. Also, if you are going to use a U polygon column as in your example, you can create a floor including the inside of the elevator bucket and empty the elevator bucket by using the floor space command. But I suggest you to do this work with "shell modeled panel" like my yellowdurmus friend.
