idecad static v10
hkderinoz
Member
Good afternoon, what is the difference between idestatic v.10 trial version and student version? Could you give information? Sent from my SM-M315F using Tapatalk
Hello there; The trial version is a version that you can download and use right now, which allows the analysis of structures with a maximum of 5 floors, and you can review the reports and drawings in the program interface without sending them to print. In the student version, after checking that you are a student, if you are eligible, it is a version that works with a time lock so that you can use all the facilities of the program for a while, there is no restriction other than time.
Hello there; If you want to start using the student version immediately, you can download the trial version. With the limitation in the trial version, you can not only print reports and drawings, you can examine the drawings and reports from the program interface, for your information. If you want to use the student version, we will ask you to share your information by calling our Istanbul or Bursa office between 9:00-18:00 tomorrow. The form on the website will be checked. Thank you for your understanding.
