ideCAD Static 8.61 Click to download
Re: ideCAD Static 8.61 *New Version* Click to download
"fyzllh":1k0srh04" said:
good evening, I have a problem with the program, everything is fine, but for some reason the program gives an error while drawing beam expansions, help on this Could you please?
Could you add your project?
Re: ideCAD Static 8.61 *New Version* Click to download Hello, Although I set the font height to 10 in the detail drawings, I am getting fractional values such as 8.89. It was not like this in the previous version. Are we doing something wrong / missing? Column, beam, curtain doesn't matter.
"MaFiAMaX":2s319kyu" said:
Hi, Even though I set the text height to 10 in the detail drawings, I get fractional values like 8.89. It was not like this in the previous version. Wrong / Are we doing something missing? Column, beam, curtain doesn't matter.
Hello Erhan Bey, When we receive the detail drawings in the program, whatever value was entered for the text height, it comes in. Does the text height change you mention occur when you export dwg/dxf? if so, it's because the "Reduce text sizes" line in the "Dwg/Dxf Export Options" dialog is checked. If you're talking about a different situation, could you add a sample project?
Re: ideCAD Static 8.61 *New Version* Click to download Levent Bey, as you mentioned, "reduce font size" option is left ticked on export screen. I forgot to turn it off after installing the new version. Let this be a lesson to me :) Thank you for your help.
