HakanŞahin
Administrator
Hello there ; Version 8.503 is now available. Reinforced concrete possibilities and improvements according to 8.103: 1- Modeling of rafter raft foundations according to finite elements together with beam, plate and superstructure 2- Making raft foundations by defining a continuous foundation only from the outer frame 3- Moment shearing force of continuous foundations diagrams without visualization 4- Modeling of continuous foundations as T beams 5- Beam-beam, continuous foundation-continuous foundation, panel-beam etc. In divisions, the element division algorithm has been improved according to the carrier-bearing element relationship. 6- General improvements have been made regarding column-foundation beam connections for continuous foundations. 7- In raft foundations, the flooring under the columns seemed to be cut visually. Now it looks whole. 8- Giving the controls in the retaining wall reinforced concrete dialog 9- In the column reinforced concrete dialog, reinforcement deficiencies were not shown in red, they are now displayed. According to version 10-7, rib beams were not shown in the cross section of the formwork plan. It is now showing. 11- In the Risky Building Analysis, polygon column dimensions appeared as rectangles in the critical Floor column limit values report. Adjustments have been made for circle and polygon column dimensions. 12- Beamed raft basically, negative printing of G and Q was perceived as negative stress in Reports. Absolute value is now printed. 13- When a rigid diaphragm is detected, a warning is given as Rigid Diaphragm-1 Rigid Diaphragm-2 instead of RD1 RD2. 14- The Risky Building Analysis command has been added to the Analysis menu. 15- Ability to choose gradient background color 16- ideCAD Wrep 8 17- 3D Printer model output has been improved Correcting the errors identified in 18-8.500 Visual C++ Redistributable Packages for Visual Studio 2015 update 3 (version no: 14.0.24.10. 0)
