ideCAD Static 7 system rigidity
SametG
In the project, the 1st basement 2nd order value is too high in the report. Increase the rigidity of the system. I got an error. How can I fix it?
More than one rigid diaphragm is visible when it shouldn't be on the floors. This is because you misidentified the slab edges without dividing them with joists. For example, in the basement, D19, D13, D65, D62. When defining the slab edge, divide by intersection should be active and the slab edge should divide the beam it is associated with.
"SametG":7l6aix8z" said:
1st basement 2nd order value is too high in the report in the project. Increase the rigidity of the system. I got an error. How can I fix it.
Other determinations and suggestions for data entry in your project are as follows; * S25 column is a polygon and a beam is drawn between it. Polygon columns are modeled as bar elements. Therefore, no beam can be entered between them. It is recommended to enter S25 as Panel objects and model as shell. (Small parts can be entered as column objects) *1. Since there are no perimeter curtains in the basement floor upper rigid basement floor number -2 must be entered *R= 7 can be taken in systems with framed systems with high ductility level (TDY 2007 Table 2.5) *Slab edge remained under S24 column *Part of the curvilinear slab edge of D51 slab is drawn on the beam.Good work
