HakanŞahin
Administrator
ideCAD Static 6.01 program is available as a BETA 1 test version for your trials and comments. Our users can update the program on 6.0055 free of charge . You can send your findings and suggestions regarding the program to destek@ideyapi.com.tr or write them under the heading that will be opened in the forum. You can download the program by clicking one of the links below. This version has been removed from access. Click
Log in or register now.
for newer versions. List of works done in the program: 1. New column application plan drawings 2. New column vertical expansions 3. New wall vertical expansions 4. Pile raft foundations 5. Contour curves and free elevation in the architectural and static program 3D terrain modeling using points 6. Well foundations 7. Display of all reinforcements in the vertical expansion of the column 8. Display of the basement perimeter walls in the column application 9. Continuous foundation superstructure interactive solution 10. Multi-stage excavation quantity calculation, including filling calculation 11. Tear in panels drawing reinforcements 12. Calculation and drawing of equipping walls such as U, T, L as shear walls 13. Detailing and drawing the walls with columns 14. Drawing the basement perimeter walls as a single wall 15. Double stirrup option in columns 16. Optimizing the number of polygon column reinforcement 17. Circular Automatic drawing of stirrups on columns 18. Drawing column expansion and column beam connection details together 19. K Arranging type columns at once in the vertical opening of the column 20. Column capacity diagrams 21. Total collapse controls for the well foundation and retaining wall 22. Letterheads in the column drawings 23. Drawing the curtain rods in the curtain openings 24. Drawing the column rod lengths with 1.5lb or 75fi options 25. Consideration of assemblies in similar floor beam openings 26. Cross-ties openings in column and wall details 27. Ability to intervene in the scales of columns 28. To be able to take into account the cohesion effect on the retaining wall 29. To be able to define plains, areas and pits in the field 30. To question the elevation at any point of the land 31. Addition option in the form of pillars on floors 32. Editing information about the project and company logo with the project settings dialog 33. Column application plan can be obtained with a single click on all floors 34. Changing the font of reinforcement in openings 35. Show/hide joint point command 36. In the building tree/elements /right click/tip force Show properties command 37. Ability to take expansions again from the opening screens without returning to the floor plans 38. Making the building tree open and closing automatically and using it with all views 39. Accessing the drawings more easily with the drawings folder under the building tree 40. Calling the reinforced concrete dialogs from the opening screens 41. multi-core support at various stages 42. A2- A3 control and report 43. In the calculation of the stirrup length of the beams, the existing reinforcement diameters coming from the neighboring supports in the upper region can also be taken into account Condition 1: After updating to 6.01 BETA 1, to return to 6.0055 again if you want, you can uninstall 6.01 BETA 1 and reinstall 6.0055 from the full install CD. Condition 2: If you want to use version 6.0055 and version 6.01 BETA 1 at the same time, you can make a copy of the folder where the 6.0055 program is installed before updating.
