ideCAD semi-rigid deformation display error
recepekmekci
When I analyze with semi-rigid diaphragm in the program, it shows the deformation model as in the picture, how can I fix this error?
Re: İdecad semi-rigid deformation display error (help
"recepekmekci":3lj2wc6g" said:
When I analyze the program with semi-rigid diaphragm, it shows the deformation model as in the picture, how can I fix this error?
Hello, Can you add your project?
Re: İdecad semi-rigid deformation display error (help only the color is purple when you hover over the point with the mouse, the deformation appears correct. file
şe_özoğul_static.ide85.html
Re: İdecad semi-rigid deformation display error (help Hello, There is no problem with your project, seeing the deformation of the whole structure in the same color scale is only related to the display and this is among our notes. Good work
Re: İdecad semi-rigid deformation display error (help I'm already aware of this, I deleted the program, I restored it again, it still looks the same. I couldn't understand the reason for the error so I asked. Thanks for your kindness to reply.
This situation occurs in some models in the basic interactive solution. If you need to get an image for a report, I suggest you solve it without basic interaction. I think it will be fixed in v9.
