ideCAD metering error
inş.müh
As seen in the pictures, the number of stirrups and mounting reinforcement in the nk1 rib beam does not match with the number of stirrups and mounting reinforcement in the quantity section, how does ide calculate them, thanks for your answers.
"inş.müh":19bsz7zm" said:
as seen in the pictures, the number of stirrups and mounting reinforcement in the nk1 rib beam, the number of stirrups and mounting reinforcement in the quantity section and the number of stirrups and mounting reinforcement in the beam do not match. .
Enter the properties of the N1 tile and you will see the typical number of teeth is 7. Now look at the N1's equipment. there is 2fi10 reinforcement same reinforcement at the top and bottom. Total of 4 pieces of 10. 4*7=28 pieces. Same as quantity. Since the same reinforcement is used for assembly and flat, they are all shown in the same item. There is no mistake. The same is true for stir-fries... Only nk1 stir-fries seem to be 14 for me. There are 2 stirrups in Nk1, 2*7=14 pieces. It's different from the screenshot you added. This value is also correct.
