Re: idecad autosave Dear sercann1221, I would like to share a few things about what you wrote. I assume you are studying architecture. -
"sercann1221":a5ost826" said:
.... autosave often doesn't save the project I'm working on, even though I turn on the autosave feature from the general settings, it saves when I put it on the desktop, but when I put the last project I worked on, the autosave feature is disabled and for this reason, the same project repeatedly I had to draw it I downloaded the latest version from the site and installed it, but the autosave folder does not appear in the idedata folder ......
- autosave: when the autosave option is active, the program
is placed in the folder where the project is saved assigns a .bak file. That is, backup files are created in the folder where you saved your project. The logic here is as follows. First, the program records itself at intervals as long as the time written in the automatic recording, and secondly, when you save it manually, you create a folder with what you have done so far. bak file. I think if you search for backup (autosave) files there you will find it. -
"sercann1221 said:
":a5ost826"] ..... when I want to create a wall on some slabs, the wall does not form
There is no problem that we know in the program in creating a wall on the slab. If what you mean by this is that there is no wall over the place, then there is no problem. Just maybe the problem is this: the floor is in static mode (on the ceiling of the floor in question) and the wall is in architectural mode (at the floor of the floor in question) I think you might mean something like this by not being able to get a wall on top of the floor. -
..... does not provide a warning or guidance on how to proceed in the face of such problems ...
The program warns about impossible things with a dialog menu. Apart from that, you can read the instructions on how to draw an object in the information line at the bottom of the program. There,
"do this, do this, select that object, select the first object" etc. There are redirects -
..... apart from these, sometimes the window positions change automatically in the project ...
The positions of the windows do not change out of the blue. The general name of windows and doors is DIO. We call them
"In-Wall Object". Here I want to say: windows and doors work attached to the walls. If there is a change in the lengths of the connections of the walls, there may be a change in the location of the DIOs. This is something related to your data entry. For example, if you said the middle of the wall while describing the wall, if the length of the wall changes, the position of the DIO will also change. Or if you entered a distance from the beginning of the wall while entering Dio, and did something about the beginning of the wall (translation with a column, etc.) -
..... as far as I know, idecadin should not perform any operation on floors other than the current floor. While I was deleting the roof on the upper floor, I could not understand the logic of the displacement of the object below....
In summary, I must say that IdeCAD is an object-based program. What you are doing is not just lines. Objects are also related to each other. Again, based on what you wrote, I can't make a roof and build a roof. If you have limited the walls under the roof with the cut to the roof command, the height of the walls will change when you delete the roof. Or, if you say automatic wall height while drawing a wall and draw a beam on it, if you delete the beam, the height of your wall will change. Here the objects are deleted. have relations with them. This being the case, not only is it a burden, but it also provides important conveniences. For example, one-click area measurement, etc. It is possible to enter information and renew itself in connected objects when changes are made. In particular, the criticism of
"not providing flexible working" is the most inconsistent of these in my opinion. Because many unbiased people admit ideCAD's flexible and easy data entry. I have to express my apologies that;
I think you haven't received enough training in the use of the program. I feel like you're directly involved in drawing projects with the general CAD habits and knowledge you've acquired. Of course I could be wrong. However, you should watch the training videos or attend one of the periodic training programs. In this way, your dissatisfaction with the program you are using as licensed will disappear and you will get rid of the
"wasted money" feeling. maybe even
"aaa can we do this too" you will encounter many topics and commands. I wish you good work. N. YILMAZ
