ideCAD Architecture 7.022 panel column and wall
cem
When I make a U-shaped panel around the elevators in İdecad architectural version 7.022, I cannot place a wall on the open end. May I know why?
Re: ide architecture 7.022 panel column and wall You should make the U curtain with the panel/curtain command, not with a polygon column. When you define it this way, you can draw a wall.
