HakanŞahin
Administrator
The ideCAD Architecture 6.01 program is available as a BETA 1 test version for your trials and comments. Our users can update the program to 6.0055 free of charge. You can send your findings and suggestions regarding the program to [email protected] or you can write them under this topic in the forum. List of works done in the program 1. Creating a profile object library 2. Drywall, skirting board, border, floor molding, under-roof precast elements, roof and dome gutter and general purpose three-dimensional profile objects created with the profile library 3. Jambs and keystones that can be defined in the desired special cross-section Intelligent jamb object that takes the geometric form of the window and door, is moved when the window is moved, and is revised according to the new type when another window is selected 4. Parametric balustrades-handrails Braille and handrail profiles can be easily defined as desired. User-defined special balustrade-handrail libraries are created by entering their horizontal and vertical numbers. It quickly settles in the logic of drawing lines in the plan. It can also be used in these objects by automatically taking the level of objects such as stairs and ramps. Different types of balustrades (metal, glass combination or french balcony type) are quickly modeled with the logic of rotated and extended object and panel feature. 5. Pool An automatic pool object is created from any closed polygon drawn from the plan. Pool; wall, floor and water features can be changed. Pools with different depths can be designed quickly by inclining the bottom. 6. Terrain modeling and excavation/filling calculation A real terrain model is easily created with elevation points or contour lines in ideCAD Architecture. Gaps, plains and special areas that automatically take the slope of the land are drawn parametrically on the land. Land dimensioning is done and any elevation on the land can be questioned. The changes in the building form are also applied on the land, providing a design process in which the land and the building are integrated. 7. Possibility to `create your own staircase` in addition to the rich staircase library. Stair contours defined by Route object can be converted into stairs. With the Add stair area command, a landing or a stair fold can be added to the existing staircase. 8. New possibilities of the roof - Defining roof detail on the roof surface - Headboard object on the roof details - Roof detail with one click on more than one roof surface (rare, Placing the roof eaves separately on each surface 9. Ability to draw curved, arc and circle beams in one piece as on walls 10. Commands to convert panel to beam and beam to panel 11. Multiprocessor / core support 12. Faster selection opportunity by seeing window types multiple times in door-window settings 13. Ability to draw doors and windows on curtains 14. Angle, radius and diameter dimensioning 15. Path object "drawing curves, arcs and lines as a single object" 16. Roof Ability to enter the contour as a path (combination of line, arc and curve) in all objects drawn by entering contour such as floor, floor, space and scan 17. Divide possibility for two-dimensional objects 18. Floor and space edge RI object was created as separate objects. Properties can now be changed. 19. Autocad 2008 Dwg, Dxf read-write 20. Automatic conversion of imported (dwg/dxf) 2D architectural projects into 3D ideCAD Architectural objects 21. Object drawing in 3D windows (obes such as walls, columns can also be drawn in perspective) 22 Operations such as moving, rotating, symmetry in three-dimensional windows 23. Optional two-dimensional object drawing in the perspective window, displaying text, dimensions and axes 24. Quickly editing the names of objects such as axis, location, beam with one click with the automatic object name command 25. Axle move tag command 26. Ability to write text with advanced fonts (line alignment, centering, giving different font heights in the text, etc.) 27. Ability to explode the text block and change the line texts separately 28. Automatic + sign display in front of the elevation placed in the positive region in the section window 29. Option to block objects while creating sections and views 30. Next to the main grid lines, set the main grid equal numbers It was also possible to work with dividing auxiliary grid lines. Auxiliary grid lines activated in the general settings can be captured by holding down the crtl key if desired. 31. The previous selection is automatically saved and the last selection can be recalled. 32. Window selection is now used to add new objects to the selected objects. Thus, new selections are added to the old selections without deleting the old ones. To drop the selected object, it is sufficient to select the window with the Ctrl key. 33. Automatic update done. The program checks the ideCAD page and informs the user whether there is an update. 34. It is possible to change object properties with double click. 35. By double clicking on the drawing screen, the zoom limits command is enabled. 36. Definition of "handrail length" for stair quantity 37. Incremental-fixed option for door-window label settings 38. If column misalignment is changed at any floor, it can be changed automatically on other floors as desired 39. Working plane definition (Working in planes not parallel to the plan plane) 40 Using route contours in distance and area commands (eg the length of an arc can be measured, m2 of a curvilinear closed area can be learned.) 41. Ability to create grid lines in third dimension 42. Various speed optimizations in the CAD interface; speeding up transitions between drawing windows, optimization for reading and saving projects containing many 2D drawings, speeding up dwg/dxf reading, etc. 43. Ability to select and work with optional different interfaces in the program view 44. Automatic transfer of shortcut keys defined in the program to the next version After updating to 6.01 BETA 1, if you want to go back to 6.0055, uninstall 6.01 BETA 1 and run 6.0055 for full installation You can reinstall from the CD. or if you want to use version 6.0055 and version 6.01 BETA 1 at the same time, you can make a copy of the folder where the 6.0055 program is installed before updating. In both cases, you can save your project as the old version (6.0055) while working with 6.01 at any time and continue working with the version (6.0055).
