ideCAD Architectural/Static Demo V 7.015
Status
Not open for further replies.
Ismail Hakki Besler
Administrator
You can download 7 version demos from our website.
ideCAD Static and ideCAD Architectural V7 features are: ideCAD Static V7 : 1) New tunnel formwork calculation and drawing module -Mesh on floors and panels Reinforced design and drawing possibilities - Belt beam definition and drawings (Band beams are not necessary for analysis ) -Tunnel formwork curtain ratio control (Regulatory equation 3.14) -Mesh reinforcement suitable for tunnel formwork exposure
[ b]2) Problem-free solving of large projects with 64-bit program versions[/b] 3) Semi-rigid diaphragm option -Inclusion of slabs (plate/rib/cassette) in the building analysis model. - Cork flooring solution with the whole building model (without using fictitious beams). - Possibility to equip the flooring elements according to the earthquake behavior together with the building
4) The entire building as shell elements of stairs, vaults and domes inclusion in analysis model
5) Possibility of cross-reinforced design and drawing, which should be made especially on the tie beams connecting the curtains on the lower floors of high-rise buildings (Earthquake regulation article 3.6.8.4)
6) New tiling features -In addition to automatic tile creation, manual tiling and space creation by defining environmental elements -With the option of drawing tiles in full on the plan facilitating project follow-up -Seeing the effect distance of the reinforcement calculation axes on the floor plan and easily changing it with the mouse -Plan the slab reinforcement calculation axes -Optionally displaying the validity distance of reinforcement axes in the formwork plan -Defining partial reinforcement axis to the floor (automatic recognition of gap and U-shaped floor arms)
8) Rebar layouts with 3D reinforcement inspection module (column/beam/panel) visual inspection (Virtual construction site) -To be able to examine the reinforcements in full screen -Drawing with different colors according to the diameter -Optionally to display only the longitudinal or transverse reinforcements
9) Broken bent axis display option
10) Command line and dynamic input possibilities
11) Drawing the capacity diagram of the curtains, querying the values of a point on the diagram with the mouse 12) Revision cloud object 13) Close unused layers command 14) Offset ability to offset axes with the offset command 15) Improvement in formwork plan sections ideCAD Architecture V7 features: 1) Displacement mapping capability
v7_disp. png
2) Ability to work in large projects without memory restrictions with 64 bit program version 3) 209 new library objects have been added. 4) In addition to automatic tile creation, manual tiling and space creation by defining environmental elements/defining space for panels 5) Command line and dynamic input possibilities
8) Revision cloud object 9) Ability to import/export Wavefront .obj files 10) Turn off unused layers command 11) Ability to offset axes with the offset command 12) Rounding the edges of the box object 13) Opportunity to reverse the opacity map values and also opacity for textures that are not created properly can be used as a map 14) Sphere object for architectural general use 15) Facilitating project follow-up with the option to draw floors/zones in full on the plan 16) ideCAD with the program lock installed Render started in Render continues after unlocking. Thus, while rendering on one computer, it is possible to continue making projects in the architectural program with a single lock on the other computer.
Status
