HakanŞahin
Administrator
The ideCAD Architecture 6.01 program is available as a BETA 2 test version for your trials and comments. You can send your findings and suggestions regarding the program to [email protected] or you can write them under this topic in the forum. We would like to thank all our users who reviewed the previous beta version and shared their opinions with us. You can download the full cd content of the program from the link below. This version has been removed from access. Click
Log in or register now.
for newer versions. List of works done in the program: 1. There is no problem when drawing a space inside the land gap. 3. General elevation can be given to the land. 4. Clicking the edge of the land selects the land. 5. Added size and unit selection to terrain settings. 6. Fixed a bug that occurred when closing the polygon when drawing the polygon terrain. 7. Some bugs in the field have been fixed. 8. The terrain command was taken from the objects section and placed under the dome-vault in the Draw menu. 9. A problem in the land excavation calculation has been fixed. 10. Facilities were made for changing the level of the land. For example, when you double-click on one of the elevation measurements of a space consisting of 10 points, the clicked point appears as selected in the land gap settings. 11. Arrangements were made regarding the bottom, top and side profiles of the jamb. 12. The problem in entering the number of points in the guardrail settings has been fixed. 13. Profile object and sub-objects are now drawn on their own layer, not on the standard layer. 14. Some errors in jamb formation have been fixed. 15. Arrangements were made regarding the jamb drawings in the plan. 16. When changing profile name, the text was reversed from right to left. It's been fixed. 17. There were no railings and jambs in the convert profile right-click list. There are now. 18. Saving the scarecrow to the library, loading and resetting the settings now works. 19. The build components report is now received on 64-bit operating systems. List of works done in Beta1 version 1. Ability to create profile object library 2. General purpose three-dimensional profile objects with plaster board, skirting board, border, floor molding, under-roof precast elements, roof and dome trough created with profile library 3. Jambs that can be defined in desired special cross-sections and keystones Intelligent jamb object that takes the geometrical form of the window and door, is moved when the window is moved, and is revised according to the new type when another window is selected. 4. Parametric balustrades Railing and handrail profiles can be easily defined as desired. User-defined special balustrade-handrail libraries are created by entering their horizontal and vertical numbers. It quickly settles in the logic of drawing lines in the plan. It can also be used in these objects by automatically taking the level of objects such as stairs and ramps. Different types of balustrades (metal, glass combination or french balcony type) are quickly modeled with rotated and extended object logic and panel feature. 5. Pool An automatic pool object is created from any closed polygon drawn from the plan. Pool; wall, floor and water features can be changed. Pools with different depths can be designed quickly by inclining the bottom. 6. Terrain modeling and excavation/filling calculation In ideCAD Architecture, a real terrain model is easily created with elevation points or contour lines. Gaps, plains and special areas that automatically take the slope of the land are drawn parametrically on the land. Land dimensioning is done and any elevation on the land can be questioned. The changes in the building form are also applied on the land, providing a design process in which the land and the building are integrated. 7. Possibility to 'create your own ladder' in addition to the rich ladder library. Stair contours defined by the route object can be transformed into stairs. With the Add stair area command, a landing or stair fold can be added to the existing staircase. 8. New possibilities for the roof - Ability to define roof details on the roof surface - A faceplate object on the roof details - Placing roof details (such as rafters, purlins, etc.) on more than one roof surface with one click - Possibility to intervene in the roof eaves distances separately on each surface 9. Curved as on the walls Ability to draw , arc and circle beams in one piece 10. Commands to convert panel to beam and beam to panel 11. Multiprocessor / core support 12. Faster selection by seeing multiple window types in door-window settings 13. Ability to draw doors and windows on curtains 14. Angle , radius and diameter dimensioning 15. Path object "to be able to draw curves, arcs and lines as a single object" 16. To be able to enter the contour as a path (line, arc and curve combination) in all objects drawn by entering contour such as roof, floor, space and scanning 17. Divide possibility for two-dimensional objects 18. Floor and space edge object are created as separate objects. Properties can now be changed. 19. Autocad 2008 Dwg, Dxf read-write 20. Automatic conversion of imported (dwg/dxf) 2D architectural projects into 3D ideCAD Architectural objects 21. Object drawing in 3D windows (obes such as walls, columns can also be drawn in perspective) 22 Operations such as moving, rotating, symmetry in three-dimensional windows 23. Optional two-dimensional object drawing in the perspective window, displaying text, dimensions and axes 24. Quickly editing the names of objects such as axis, location, beam with one click with the automatic object name command 25. Axle move tag command 26. Ability to write text with advanced fonts (line alignment, centering, giving different font heights in the text, etc.) 27. Ability to explode the text block and change the line texts separately 28. Automatic + sign display in front of the elevation placed in the positive region in the section window 29. Option to block objects while creating sections and views 30. Next to the main grid lines, set the main grid equal numbers It was also possible to work with dividing auxiliary grid lines. Auxiliary grid lines activated in the general settings can be captured by holding down the crtl key if desired. 31. The previous selection is automatically saved and the last selection can be recalled. 32. Window selection is now used to add new objects to the selected objects. Thus, new selections are added to the old selections without deleting the old ones. To drop the selected object, it is sufficient to select the window with the Ctrl key. 33. Automatic update done. The program checks the ideCAD page and informs the user whether there is an update. 34. It is possible to change object properties with double click. 35. By double clicking on the drawing screen, the zoom limits command is enabled. 36. Definition of "handrail length" for stair quantity 37. Incremental-fixed option for door-window label settings 38. If column misalignment is changed at any floor, it can be changed automatically on other floors as desired 39. Working plane definition (Working in planes not parallel to the plan plane) 40 Using route contours in distance and area commands (eg the length of an arc can be measured, m2 of a curvilinear closed area can be learned.) 41. Ability to create grid lines in third dimension 42. Various speed optimizations in the CAD interface; speeding up transitions between drawing windows, optimization for reading and saving projects containing many 2D drawings, speeding up dwg/dxf reading, etc. 43. Ability to select and operate optionally different interfaces in the program view 44. Automatic transfer of shortcut keys defined in the program to the next version
