Hello You may have encountered this error because you used special characters such as fi, lowercase equal in your message. If you correct these characters, it will be fine."NYILMAZ":3grdr811" said:General Error SQL ERROR [ mysql4 ] Incorrect string value: '\xE2\x80\xA6 H...' for column 'post_text' at row 1 [1366] A sql error while opening this page If this problem persists, please contact an administrator.
If you can't add your project because the size of the project exceeds, you can add it to this site and share the link."Nurullah Yurdigül":10ck2b02" said:I can't add the project. Can you help?
