I start analysis and then I get ideCAD has stopped error
Hello. Do not look for a solution to such problems with the abolished TDY2007 and ideCAD static 7-8 version. (Even if you solve it, it won't work.) Solve with current TBDY2018 and ideCAD static 10. Unver ÖZCAN
I looked at your project yesterday. There is a segment of element at the point shown rm and km (at the coordinates specified in the analysis). Obviously I select it but I can't delete it. I couldn't figure out which element it belonged to either. Respectively; Tile edge / select all / delete Tile, all, delete Beam, /all, /delete Column, all, /delete Screen/ I could not delete the object even though I said select/delete. I selected the object by itself and could not delete it. I selected the object and edited the object, but it did not edit any of the objects. I copied all floors, layer by layer, except for that object, and merged them in the new file. The same problem persisted. I didn't look at the individual junction points anymore. I couldn't answer because I couldn't solve it so I gave up. Now friends from ideYAPI can reply. I wrote what I wrote above in detail in the sense of being a debugging method. Good work. N. YILMAZ
The part you said yes caught my attention, but I couldn't understand it, so I messed around a lot when I saw that part in the coordinates. But still thank you for your effort. I hope you get an answer.
"hatice.mert":3tu234tt" said:
http://dosya.co/x42bxgxa6stu/233-1.ide I start the analysis in my project that I sent in the link and then I get the error idecad has stopped. can you help me how can I fix it?
Hello , "Object Trim Method command" Change the trim algorithm of the right end of the K205 beam on the ground and normal floors. Analysis will be possible in the project. It is a situation caused by version 7. This situation does not occur in versions 8 and 10. Good work
Mr. Levent, thank you for your help. Is the weak floor error after the analysis given because the columns on the left side are not connected to the beams and are not included in the effective area?
