Dear, I would appreciate if you could answer my questions in the project that I have sent in the attached attachment; When I create a connection element between the 1st reinforced concrete column and the steel column, I have a relative floor drift problem. 2. I get an error in horizontal edge distance in cross-end joints and it does not improve. 3. What do you think the choice of R coefficient should be? Bolt number error occurs in the 4th butt plate beam joint. 5. I am getting an error even though there is no conflict in the conflict checks.
