I had some questions..
evanes07
1) There is an error (ab) in the column and beam, but it reports and no error appears when I examine the report? 2) In the beam reinforcement area, the required 0 excess 4.52 cm2 is said in some beams on the left and in the span, is too much reinforcement used? 3) The program usually chooses 18 and 35 slab main and additional reinforcement intervals, but when we make them 20 and 40, the slabs usually do not give an error. How do we get it to choose this way? 4) When the additional reinforcement diameter fi8 is selected on the raft, it provides a little reinforcement economy, but it will be crowded and the price of fi8 kilos is slightly higher. From this point of view, how correct is it to use fi8 in addition to the raft?
"evanes07":1ckw3mtj" said:
1) Column and beam (ab) error shows up, but it reports and no error can be seen when I examine the report?
The beam may not be adequately supported on the column. There must be a problem with the beam reinforcement placement. [quote ="evanes07":1ckw3mtj"] 2) In the beam reinforcement area, in some beams, the required 0 excess 4.52 cm2 in the left and span, I wonder if too much reinforcement was used?[/quote] Due to the minimum pursantage, a certain amount of reinforcement should be placed on the beam. Since the beam in question was not forced, it may have been crossed with minimum reinforcement. This does not mean that excess reinforcement is used. According to the regulation, you have to put the equipment that meets the minimum purchase conditions.
3) The program usually chooses 18 and 35 slab main and additional reinforcement intervals, but when making them 20 and 40, the slabs usually do not give an error. How do we get it to choose this way?
Looking at the attached picture You can intervene whatever you want to change.
4) When the additional reinforcement diameter fi8 is selected on the raft, it provides a little reinforcement economy, but it will be a crowded image and the price of fi8 kilos is slightly higher, from this point of view, how much is it to use fi8 to add to the raft would it be correct?
It is not correct to use 8 in raft flooring reinforcements. Do not use less than 12 gauge reinforcement.
