I got an issue with punching reinforcement in raft
ammer
he admin
i got an issue with punching reinforcement in raft.
even where i changed the punching data reinforcement in the column properties, i can not see the changes....
where can i find the value of the punching reinf. ?
Hello,
Punching reinforcement drawing is not made automatically. Using the 2D options you can draw the punching reinforcements. The punching reinforcement calculation results is given in the punching reports.
hi levent
thanks for your replay
I need to know the punching shear area steel "Av" design shear in the table
so i can compare it with the shear force acting under the columns.
and if possible manually draw the shear punching for your example image attached if you please :) :) :)
hi levent and admin
Hello Ammer;
You choose the punching rebars from the column and shearwall menu. The program is controlled whether ıt's enough or not. Therefore, you see the cross section area, and stress control at the report.
