I GET RELATIVE FLOOR OFFSET ERROR
Hello there; 1- You can change the direction of some of your columns to the y direction. 2- If you are using a central crossed system, make sure that the crosses are inserted in the y direction. You can slightly increase the cross and beam sections. 3- You can increase the column sections. **4- Use cross for stability on the roof, it will change the ratios.
