I get beam error message in build summary report
Oznb
Although there are no errors in the program, I get an error message about beams in the calculation report. Solved with version 10.58. Can you check
Re: Beam error message Hello In previous versions, section checks and found errors in geometry control have been added to project errors report and Structure summary reports. If you update to 10.59 it is also listed in the Project errors report. You can update from the link below.
