I get a warning that we are running out on the starting edge of the output line
gokaygnn
While creating the ladder specified in the project, I get a warning that the output line cannot end at the starting edge. I would appreciate it if you could help me
You have made the route line passing through the head of the stairs from one end to the other. Make the route object as in the example in the file I sent. Separate 2-3 cm from each other (I made 5 cm)
I need to draw some digits (in rotary digits) single. When I draw it, it defines it as a landing and I cannot turn it into a ladder. When I draw this spiral staircase with 2 steps, it perceives it as redrawing it this time and numbers the step number as 12, I could not solve this situation.
