I export dwg, the file is empty
There is no prepared drawing in your project. I think you want to export DWG from 3D Floor plans. In this case, the error you mentioned occurred. I will forward it to the software department for review. Convert the plan into a 2D drawing using the "Create 2D Drawing" command in the Tools menu. Export the 2D drawing. DWG drawing occurs. I can recommend this for now.
No, I am creating the drawing, I see it with my eyes, then when I say export, the dwg file of some floors is empty, I just deleted the files in the project so that the file size would be smaller while uploading it to the site
Also, for example, I will get the beam details, although I selected the "all floors" option, it only gives me the beams of the floor I am on, so I get drawings from each floor one by one, how can I overcome this problem?
I created and tried 2D drawings such as column/wall details, formwork plan beam expansions. We can re-create the drawings that you cannot export, and test which sheet you cannot export and the export settings you use.
"mkrts88":3le0kqg4" said:
and for example, even though I selected the "all floors" option where I will get the beam details, it only gives me the beams of the floor I am on, so I get drawings from each floor one by one, how can I overcome this problem
Beam expansions are taken layer by layer If similar floor status is set in the "Similar floors" tab in the beam drawing settings dialog, the details of 2-3 floors can be taken in one sheet.After drawings are taken, the layouts can be combined using copy paste commands.
