I do not draw 2 windows on the same wall at different levels.
nslkn
Hello; I'm using version 7. I can't draw two overlapping windows on the same wall. For example, I want to draw 2 150/50 windows at the same projection but at different elevations (overlaid) in order to provide light on the wall that forms the stairwell. However, I couldn't find a solution. I would appreciate your help.
Re: draw 2 windows on the same wall at different levels on the same wall at different levels, door, window, gap etc. It can be drawn only after putting the 1st window, it is enough to select the 2nd window and click on the wall.
Re: draw 2 windows on top of each other at different levels on the same wall sec nslkn hello, Since there is an object control, you can define a door/window object with the same coordinate on the wall at different elevations only when you change the placement distance. After creating the window, you can enter the value you want in the layout section in the setting dialog. In the appendix, the placement distance from the wall (0.4-0.5) of the two doors at different levels on the left is defined differently. Good work...
