Hakan KARAKUŞ
Hello friends, I could not fix the beam deflections in the attached project, only 6 beams are deflected, the openings are too much, can you help me?
Hello, version 7 also has semi-rigid diaphragm solution."Hakan KARAKUS":1s5zdcbv" said:Thank you for your help, but unfortunately I don't have version 8, I have 7, I couldn't solve semi-rigid in 7, is there any other way I wonder how can I solve it in version 7? ?
"Hakan KARAKUS":1v0qz8xs" said:There is, but the number of mods is insufficient, it gives an insufficient warning when I manually increase the number of mods, I couldn't figure out what I did, can you help with version 7?[/quote ] More modes are needed for mass participation ratio in semi-rigid diaphragm. Eigen vectors method is used for calculating mass participation ratio in version 7. In version 8, also ritz vectors method is introduced and 18 modes are sufficient with ritz vectors method. You can consider switching to version 8 if necessary. For insufficiency of deflection, the dimensions of your beams seem insufficient according to their spans (there are beams with 8 m spans). Also, some of your beams give errors in terms of moment according to vertical loads. Dimensions are insufficient. I am in the opinion of reviewing the load-bearing system.
