i changed the direction of the rib in a tile it gave a few errors?
gencideci
I made a project, there was no error in the report. While arranging the formwork plan (in my project consisting of 2nd basement, 1st basement, 1st floor and 1st floor), I noticed that the ribs on the floor of the living room before the balcony on the 1st basement floor are facing the short side. I turned it over and analyzed the long side and it gave 3-4 errors. I couldn't understand getting these errors from something so simple. Why is it so important? rigidity in the project. in good condition. Is there any problem if I take the report like this and map it as corrected? The project of a district does not push the municipality too much, but it still does not bother me to make it up late.
Re: I changed the direction of the rib in a slab a few mistakes and locked the columns and beams when the project was finished. When the rib changed direction, larger reinforcement was required, and because the columns were locked, the shear safety error occurred when the reinforcement was not raised...
Re: I changed the direction of the rib in a slab, a few mistakes and First of all, the situation you mentioned can affect many things 1) because the stiffness distribution of the system changes, it can affect the oscillation. 2) Since the beam carrying the rib slab changes, that beam may be forced, accordingly the system is forced. 3) Since the beam is forced, its reinforcement may increase and the investigation of the column-beam junction area may get into trouble. respects.
