I cannot assign ready objects to the program.
etika1401
Hello, I cannot import the objects in the folder I downloaded from the All Ready Objects link you gave into the ideCAD program file. A warning comes up saying you need to provide administrator permission. How can I use these objects?
Hello, First of all, I suggest you to turn off your antivirus and try it. You can right click on the folder you want to copy and select properties/security and increase the folder permissions. If it still doesn't work, we can connect and view it remotely with teamviewer. You can access all libraries in the ideCAD portal.
Good luck, keep up the good work.
