I can open as WREP but not save as WREP
Re: Saving as WREP Hello, the file type of the IdeCAD Wrep program and the file type of the Licensed programs are the same. When you save the file with the save or save as command, it is saved with the *ide10 extension. If you are getting an error message while saving your project in IdeCAD Wrep program, please attach a screenshot of the error message. Good work
Re: I can open as WREP but not save as WREP I did not encounter an error. I want the person to be able to open the file only as WREP, is this possible?
Re: I can open it as WREP but cannot save it as WREP
"huseyinakkus56":34i7nxzj" said:
I did not encounter an error. The project file saved in the licensed program is opened in the ideCAD Wrep program.If there is a version difference, you can save your project with the "Save as old version" command.
Re: I can open it as WREP but not as WREP If I do it this way, will the other party be able to open it "only" as WREP or will it open as ide10 if they want? Because when I save it as you show, it saves as ide10.
"huseyinakkus56":29zb6s00" said:
If I do it this way, will the other party be able to open it "only" as WREP or as ide10? Saves as ide10. If you want to see only the drawings that you will print out in your project, you can delete the other data in the file and save it with the "Save as" option and give this file to the other party.
