I can't stub Help
yck86
Good evening, I need help with a subject that I was confused about, today my stud beams are not supported, yes sometimes such a situation can happen when I don't pay attention, and then I fix it, but I don't understand if it was the computer or the ide's settings or me, I did not understand if it was something wrong with the last 25cm apart, I did not work again, I wonder. If there is a setting related to this, did I turn it off? I added the project.
The problem is on my computer or in the settings of the ide on the computer, I think I tried it on my other computer, I just wrote it so anyone who has the same problem can give an idea, because a very bad situation is on my nerves for exactly 3.5 hours. Good night everyone again.
"yck86":3cidelwq" said:
The problem is on my computer or in the settings of the ide on the computer, I think I tried it on my other computer, I just wrote it out of the blue, if anyone has the same problem, I'm writing in case anyone has an idea because it's a very bad situation for me for 3.5 hours. Good night everyone again.[ /quote] Hello, it will be useful for the project to pay attention to the existing nodes, the corrected version of the project in the appendix.
"yck86":1u9kpwyi" said:
good evening I need help with an issue that I'm confused about today my stud beams are not supported, yes sometimes such a situation can happen when I don't pay attention and then I fix it but I don't understand if it's something wrong with the computer or the ide's settings or me I threw axles on 4 sides with the last25cm spacing, it still didn't work, I wonder if there is a setting related to this, I turned it off? I would be very grateful if you could help me, thanks in advance. I added the project.
"cakilomer":3oafetyz" said:
"yck86":3oafetyz" said:
I think the problem is on my computer or in the settings of the ide on the computer, I think I tried it on my other computer, I'm writing it so that if anyone has the same problem, you can give an idea, because it's a very bad situation, my nerves are full. It's been 5 hours. Good night everyone again.
Hello, it will be useful for the project to pay attention to the existing nodal points, the corrected version of the project in the appendix. good work
Thank you for your attention, as I mentioned, the problem was in the settings, I handled the project on the other computer last night, when I reset the settings of the computer I normally use today, the problem disappeared. Thank you again.
"Levent Özpak":3l7moztj" said:
"yck86":3l7moztj" said:
good evening I need help with an issue that I am confused about today my stud beams are not supported, yes sometimes such a situation can happen when I am not paying attention and then I fix it but to the computer? I didn't understand whether it was something wrong with the ide's settings or me. I threw the axles on all 4 sides with 25 cm intervals and it still didn't work. I wonder if there is a setting related to this, did I turn it off? I added the project.
Hello, "Divide intersections" command in Beam helper toolbar may not be active. Good work
Hello, Mr. Levent, when I initialized the settings, my problem disappeared, probably the divide by intersection command was not active, it was fixed, and of course, I probably couldn't realize it with that panic, thank you for your interest, good work.
