I can't set wall colors
demir
I FOUND AN EXAMPLE PROJECT I DONE NEARLY EVERYTHING BUT I CAN'T ADJUST THE WALL COLORS AND THERE IS A SHADOW ON THE DOORS WINDOWS HOW CAN I DO? THANKS NOW..
Re: FRIENDS ANYONE TO HELP? Hello; You can solve the problem if you make the angle of the sun with the zenith zero from the render settings.
In the dialog that opens when using the section with roof command (where you trim from the bottom-top), the selection process related to the colors of the cut surfaces is displayed.
