I can't render ground floor
demir
I CREATE ROOF SURFACE I CUT IT WITH THE ROOF I SAID LOCK THE ROOF SURFACE FROM LAYERS BUT IT IS NOT LIKE THIS PICTURE, THE ROOF SURFACE IS AGAIN PLEASE HELP..
Re: I CANNOT RECORD FLOOR FLOOR I did, but I want to ask one last thing about this issue, when rendering, shadows appear on walls and doors, what should I do? thanks in advance..
Re: I CAN'T RECORD FLOOR FLOOR Hello, After cutting with roof, go to layer Settings and turn off roof surface layer. (The roof surface will become invisible) A shadow is formed depending on the position of the sun, if you set the shadow to 0 under the physical sky option in the render settings, the shadow will be removed. Take it easy, good work..
Hello, The selection process related to the color and texture of the cut surfaces comes from the trimming dialog that appears while the cut with roof is performed. Have you attended our trainings before? Our program trainings are held in Istanbul and our Bursa office on a monthly basis. If you are a licensed user, you can get detailed information about your questions by calling our office at 0212 2205500 and remote access support. Take it easy, good work..
Thank you I did. I would love to come to your courses, but I can't because I have no time. I always learned with my own efforts, I wanted to make such a plan, so I got stuck. I will be sharing the library in a few days, especially children and men, I am a user of 7, take it easy, thank you for everything.
