I CAN'T RECEIVE THE DRAWINGS
elifabus
Hello there; I can't get my project drawings due to a problem that I don't know yet. When I draw the basic application plan, it gives the section drawings incorrectly. The same problem arises with die plans. I need your help very urgently. Thanks in advance
run X: 0 ; Y: This is a problem because you can't create at 0 coordinates. When it is cross-sectioned, the area entering the cross-section becomes very large and the drawing becomes small. You can see your drawing by selecting them with the select all command and zooming. Good luck with. Also, delete the other lines when you install the system. In large projects, the system is tiring.
"elifabus":23s2a2lg" said:
Hi; Due to a problem that I do not know yet, I cannot receive my project drawings. When I draw the basic application plan, it gives incorrect cross-section drawings. The same problem occurs in formwork plans. I need your help very urgently. Thanks in advance[/quote ] Hello, As Mr. Sarıdurmus said, the drawing was created in a coordinate far away from the origin. It would be appropriate to move the lower left corner to a coordinate close to the origin point. Also, a beam was entered between the S10 polygon column. Since the polygon column is a bar element, no beams can be entered between it. Instead of a polygon column It is recommended to enter a panel object.
I moved the carrier system to x=0 y=0 coordinates and now there is no problem. I can easily get the drawings. Thank you very much for your help; good work:)
