I can't put jambs on some window models
Meakka
Hello, I can't put a jamb in a "Dpen15" model window. This is what happens when I put it.
"Meakka":3ufvyu81" said:
Hello, I can't put a jamb on a "Dpen15" model window. This is what happens when I put it in.
Hello, There is a problem in the placement of the jamb due to the gap polygon of the window type you selected. Attached is the dio' of the same type with and without sills. This has been corrected.Download these files from the attachment and copy the windows in the attached dio folder into the dio folder in the folder where idecad Architecture is installed.This way, the problem will be solved.
