I can't add a connector
bektasmehmetali
hello, I just started to play around with the program, I just graduated, my technical knowledge is fresher, but I have no experience. In the project I have attached, how will I connect the steel column (he 240 a) that I have specified in the middle with the steel truss (which connections) and does the program automatically define the support for the reinforced concrete column and the truss, or should it be the connection that I need to specify extra (I tried a few but very bad connections) , for example, which links should be used correctly) and I got a lot of errors in the program about steel. I think that the sections I have specified in the profiles are sufficient and I still get the errors of section insufficiency and insufficient pmm rate. I could not understand the reason. Thank you very much for your support and information. I couldn't find enough resources for fasteners on the internet. Do you have a resource or document that you would recommend, especially for the definition of connection types (for someone who is new to the steel program :) ) because the file is large, I have to throw it like this (
Hello there; A few support combinations have been entered as an example for your project. You need to arrange the reinforced concrete side. The full reinforced concrete column, beam and truss elevations overlap, so there is no room for the truss to join. It would be good to consider the manufacture while making the scissors triangular and give the start and end heights of around 30 cm so that the lower and upper heads do not overlap. Apart from this, you have made the trusses close to the outside of the frame in the first and last truss, but you cannot connect the support joint to the column in this way, arrange them so that they come to the middle of the column. Also use wind connection for steel column truss. Your cross-sections are insufficient because the supports are not formed, you can see if your first trusses are deformed under vertical loads, if you examine them. You can enter joins to fix these errors. Register and participate in the trainings of the program on our website. If you are from outside of Istanbul, please follow the videos in the link.
Good work.
