Hello Ammer,
You should use slab edge commend. You should draw slab contour and opening with slab edge commend and then define the ribbed slab.
*** In the rib and waffle slabs, the slab openings cannot be defined so as to divide the beams. Statically it is not appropriate to define the rib on the cantilever, it is appropriate to support the ribs on the secondary beam.
