1-)
-Run the "Label entities" command.
-Name the object in the dialog that opens.
-Select the columns in the order you want to name them.
-Press the enter key to terminate the command.
2-)
-Select the columns on axis B. Run the "Auto Label entites" command. In the dialog "Check Generate labels for this story" Click OK.
"Auto label entities" dialog will open. Give a name and "check left to right" option
Then select the columns on the D axis and Run the "Auto Label entites" command again.
Give a name and choose "Right to left" in the dialog
