good work, in the field polygon work that I have attached, I can only intervene in the ( z ) unit of each polygon point in the field settings window. How can I fix point no, x, y units? How can I intervene? Thank you for your interest...
Re: land Select the point you want to change on the plan plane, then press X from the keyboard in the coordinate box, enter the value you want and press enter. After doing the same for the Y value, the change will occur. Take it easy, good work..
