How to export screenshot for slab reinforcement
ammer
hello
i have the below image for the slab reinforcement ,
how to export it to dwg extension or image with scale?
regards
Hi Ammer,
The image you added is generating as the colored pixel view, it's not as vectorial drawing. Simply you can use sreenshot as image file(jpeg, png etc.) that you added here. There is no such as feature in this program you asked.
There are some small programs that converts jpeg to dwg but you can't view exaclty as colored view, you will see some contoured lines around. You may search for them on google by writing "jpeg to dwg "
hello
I thought that i could TO do an export DWg for the moment or steel reinforcement diagram directly inside idecad
means
i want to measuring the the moment or steel reinforcement diagram to obtain the required steel
