Hello, detailed information about the definition of basement curtain can be found at the link below. [url ]http://www.idecadsupport.com/forum/viewtopic.php?f=21&t=2015[/url]"ertub_23":ou5kt4xj" said:HELLO HOW TO DRAW WATER CURTAINS ON CONTINUOUS FOUNDATION.
If you are asking this question in terms of idecad Static, there is no possibility to define linear load on hollow blocks. Therefore, it is appropriate to add the wall load to the slab fixed or live load."ertub_23":ou5kt4xj" said:WHY IS WALL LOAD ADDED TO MOVING LOAD ON RIBBED FLOORING .
"Levent Özpak":fb9pfrxz" said:Sn. In Levent Bey V 7.022, a linear load can be entered on the hollow floor slab and this load can be seen in the report. Can it be used on accounts? In version 7.022, is it possible to enter a linear load on the hollow floor slab?? Have a nice day..."ertub_23":fb9pfrxz" said:WHY IS A WALL LOAD ADDED TO MOVING LOAD ON RIBBED FLOORINGS? If you are asking in terms of hollow blocks, there is no possibility to define linear loads on hollow blocks. Therefore, it would be appropriate to add the wall load to the slab fixed or live load.
Linear and point slab loads are effective on slab slabs.Linear loads on rib slabs do not affect rib teeth.Good work"celikbey":1b3qr7id" said:Mr. Levent Bey V 7.022, linear load can be entered on the hollow floor slab and this load can be seen in the report. I wonder if it can be used in calculations? Is it possible to enter linear loads on it? Good day...
