HakanŞahin
Administrator
In this example, two first 10 inch long rectangular rod elements are used. One end of these rod elements is flush-mounted, the other rod element is defined as one end is fixed support and the other end is fixed support.
In the first system, the free joint displacement value will be calculated, in the second system the axial pressure force due to temperature change will be calculated.
click on the link below for temperature load manual calculation explanations
Log in or register now.
