Re: render 2 help Hello; There is no single parameter for a visually good render. The properties of the materials (transparency, reflection, resolution, etc.), the quality level you choose, the position of the sun varies according to features. In this render, I can play with the materials that I can suggest, I can suggest you to reduce the reflection of the glass on the curtain wall and increase its transparency. I recommend you to use another material instead of wood on the facade, it will be more realistic if you choose the grass darker and make the grass feather effect active. You can also reduce the angle of the sun with the vertical a little more, it may be better to illuminate a little more. For a good render, you need to play with all these parameters and take multiple trial renders of low quality until you find the best rendering visually. Take it easy, good work..
