How connect the dome to the ring beams ?
Re: how connect the dome to ring beam?
ammer":1j7js4t1 said:
dears i need to know how to connect the dome to ring concrete in the vault window?
Hello Ammer,
Click dome edges in order that you want them as support with beam. You will need to analysis doom with structural together, so you need to select second option named "Boundary conditions for solution with building system" in that dialog you added here. Select option " Connect to beams".
1. click "Set boundary connection"
2. click one of edge of doom on plan view.
3. Select option " Connect to beams"
4. Click close
5. Rapid it for other edges for beams or other objects if its required.
Don't forget to select "use semi diaphragms" option in Analysis Setting. When you make analysis, dome and building will analyse together. After finishing this, click "dome/vault analysis" on toolbar to analyse dome.
You can see deformation dome and building together on 3D frame view(visualization).
hello dear hakan
i will attache the small model with dome.please review it and set all necessary modifies
. :D :D :D :D :D
and one more query
if i set mm for reinforcement ,why it still output by cm2 ???
ammer":z3qwhsu4 said:
hello dear hakan
Dome and building cant analyse together in version 8 for now. This issue is in our note. You can analyse dome separately without building. You can give dome loads to beams yourself to analyse building with dome loads
and one more query
unfortunately we cant change units system in drawings. All reinforcements will be given as cm
Please note that you cant define beam over beam as you did in your project.
ok mr hakan ,would you please fix my issue in model ?and upload it in the page
thanks
For separate analysis:
I set Translation restrained on dialog.
I deleted beams over beams.
You can give dome loads to beams with "add load" command for building analysis. (Select beam, click right button and you will see "add load" command)
See bars in dome dialog that I gave (fi14/15). You may change them if you need something else
