How can I deal with insufficient reinforcement on raft without beams?
Re: How can I deal with insufficient reinforcement on raft without beam? Good afternoon. In the project in the link I gave, I get reinforcement error in the columns, but I do not understand the reason. Although there is 1 floor above it, it gives an error and 3 of them say that the equipment is insufficient in the elevator tower. I'm leaving the link, I'd be very happy if you help That's why the old licensed building was renovated according to the 2007 regulation. Also, D11 gives an error that the network cannot be created?
İK6666.rar.html
Re: How can I deal with insufficient reinforcement on a beamless raft? Hello
"batuhann28522":3tbltvs9" said:
Good day. I am getting reinforcement error in the columns in the project in the link I gave, but I do not understand the reason. It gives an error even though there is 1 floor above it. and one of them says that the equipment is insufficient in the elevator tower. I leave the link.
Re: How do I deal with insufficient reinforcement on raft without beam?
"unver":1pi2bxwa" said:
Hi
"batuhann28522":1pi2bxwa" said:
Good day. In the project in the link I gave, I get reinforcement error in the columns, but I do not understand the reason. Although there is 1 floor above it, it gives an error and 3 of them say that the equipment is insufficient in the elevator tower. I'm leaving the link, I'd be very happy if you help According to the 2007 regulation, the analysis was made and the old licensed building was renovated. That's why
Why are you making a solution according to TDY2007? Ünver ÖZCAN
This project was done in 2018 and now it has been tasted, some of it has been done on the spot, so I need to have an analysis according to 2007. There is an error that the network cannot be created in D11, can you help?
"batuhann28522":28he0hh8" said:
Good day.I am getting reinforcement error in the columns in the project in the link I gave, but I do not understand the reason. It gives an error even though there is 1 floor above it. It says there is insufficient equipment in the elevator tower. I leave the link, I would appreciate it if you could help. The old licensed building was repaired according to the 2007 regulation, that's why. It also gives an error that the network cannot be created in D11?
İK6666.rar.html
Hi, due to the regulations made for column transverse reinforcement spacings in -Ver 10 according to TBDY 2018, the confinement zone conditions for TBDY 2007 are automatic. (Automatic control is only done according to TBDY 2018.) Save your project as an old version and solve it in Ver 8.62. -Edit the offset of the K18 beam with its name on the ground floor as 5 cm. Networking problem will be fixed. Good work
Re: How can I deal with insufficient reinforcement in beamless raft? Hello. In addition to what Levent said, you need to remove the ground and 1st basement floor rigidity ticks in both X and Y directions, since the curtains on the left and right of the building are not connected to the building with sufficient rigidity. Unver ÖZCAN
"Levent Özpak":11hlnk6i" said:
Hello, -Ver 10 for TBDY 2007 due to the regulations made for column transverse reinforcement spacing according to TBDY 2018 Cling zone conditions are not controlled automatically (Automatic control is only done according to TBDY 2018). Save your project as an old version and solve it in Ver 8.62. - Edit the offset of the K18 beam with its name on the ground floor as 5 cm. The mesh formation problem in D11 will be fixed. Good work
Good afternoon. I saved it in version 8.62, but it won't open, it closes the program, how can I find a solution?
"batuhann28522":1c9ki90q" said:
"Levent Özpak":1c9ki90q" said:
Good day. I saved it in version 8.62, but it does not open, closes the program, how can I find a solution? Is it because there is a load of version 10?
Hello, the version of your project that can be opened in version 8.62 is attached.
