Re: HOLLOW FLOORING IT IS NOT WORTH IT TO COMMENT ON THE PROJECT WHICH IS BEING A BEAM AS IN THE ADDED MOLD PLAN. PLEASE LEARN TO DO THE PROJECT WITH SOMEONE THAT KNOWS AND DO IT. COW SUJUK METHOD HAS BEEN A PROJECT. Ünver ÖZCAN APPENDIX: MOLD PLAN
Hello, The only non-continuous console in the program is defined as closed ribbed ribbed slab. Other than that; *Linear slab load command can be used on slab floors. Instead of this, the fixed or live load values of the slab can be increased. *It would be appropriate to give the same name to the split beam parts between S3-P01. Good work
