I izmirlimuhendis New Member Nov 14, 2013 #1 While determining the hollow slab directions in a formwork plan, is it correct to transfer the loads to the short beams or to distribute the rib beam directions in the x and y directions in a balanced way?
M matrax New Member Nov 14, 2013 #2 usually the shorter one should be rotated according to the beam as far as I know because the smaller beam should work against bending...
I illaga New Member Nov 17, 2013 #3 The ribs are designed in the direction of the long side so that they can transfer load to the beam in the short direction.
