Hello, After defining the steel column and steel beam from the steel menu for the roof, divide your steel beam into 2 with the divide command in the change menu. Select the node where you have divided and enter the dz value as the height. After defining the purlins in the steel menu, you can define the coating and define the tile texture you want from the coating settings material menu. Take it easy, good work.
