help
saridurmus
Friends, I have a project that I need to solve with a pile foundation, is there anyone who can help with the source? Thanks in advance for those who want to send documents.
In my project, the basic equipment is constantly insufficient and there is a very abnormal difference between the required ace and the current ace (v 6.053). Is there a solution for this? I would appreciate it if you could help. I couldn't add the project because of its size
Even if you don't say the foundation type, I think it's always basic. Since corner columns and walls are exposed to large moments, there may be reinforcement problems in the foundations under these carriers. If the building is not adjacent, you can relax the system with console exits. also if you save your project by zip and send it here, it can be reviewed good work
When I record with compression, the file is 4 mb. It takes up more than enough space so I couldn't put it here. The system consists of basement floor, 11 floors and raft. There is no problem in my ground tension. just as necessary as abnormally much.
