Help With Stairs and Roofs
Tolga CESMELI
Good work, I will list some of our needs that we could not or could not do during our work on the architectural program. How can we cut and draw the stairs with this logic In this way, when I cut 1.5m on the 1st floor, I need to see a step like 8 of the ladder that goes from 1 to 2 and see the ladder from the floor to 1 in the remaining area. Since it is detected, the section line feature in the staircase settings remains in the selected area. As a result, when I cut in the first area on the plan, it should see the remaining ascending areas as after the section line, but only the contents of the cut area are seen as after the section line. How can we draw this * We have to create a roof with a roof surface in types where the roof cannot be created automatically. However, the end types of the roof on the automatic roof are not available in the roof surface options, so our roof sits on the eaves reinforced concrete slab as high as its thickness and this creates problems in the official project view sections and heights. * We cannot draw rafters, sills, etc. on roof details. * Again, when all of the sills and ridge rafters are defined on the roofs, there is a problem in the display. Sometimes the rafters are visible, and sometimes the ridges are visible. As a result, we have to draw all of them separately and superpose them in the 2D window. Of course, this problem occurs in sections. * When there are uses such as storage rooms, etc. in the attic, the attic plan is requested by the administration, and I cannot take it to my drawings because the stairs I mentioned above are on the lower floor. we also see extra surfaces such as the eyelet stairlift tower on the roof as if they are at the same level as the plan, we can see them as desired. * Finally, when the section is taken, when the floor definition is written, it shows the elevation next to it, it gives elevations such as 2m 5m, how can we bring the separation there to the actual value of the elevation, for example 2.85 5.70 etc. I haven't added a project as my questions are occurring in various places within our projects for now, but I can add projects if it should be seen that we have projects in the record for each situation. Thank you for your interest.
* Plaster is not defined on the panels, but if we want to see the panels plastered, you can draw a wall over it, you can activate the panel scanning from the layer settings and drawing details in the scanning. *The program complies with the standard stair drawing details. (If you double-click on your stair and tick the "There is a cross section line" box from the areas tab, the cross section line is drawn on the relevant stair area (arm) according to the parameters entered. In the view option, there is a separate line type for the lines forming the staircase. Line according to the state of the steps you want to appear You can change the types, blast your ladder and copy it to the upper floor in 2D and make the adjustments you want, but if the display you want does not occur, you can call our Istanbul or Bursa office and get support.*If you sample the part that causes the problem in the roof type, a healthier response will be made.*The situation of not being able to define a roof detail to an eyelet is available in our job list. (We can recommend creating with 2D drawing tools) *It will be helpful if you inform our technical service about the problem in the details of the roof through the sample project. (You can get help from our technical service) *When the section is taken, you can set the actual level value you say from the number of digits in the section level settings in the units section. Take it easy, good work..
Thank you for your answers, we have already handled it with the 2D tab in our project, but plaster definition needs to be made on the panels, after all, we have solved a plastered building element in 2D. I think I sent an e-mail about the project for my other questions, I will get help on the phone, thank you
