gradual foundations
We have solved the project here, but we get the error that the stiffness coefficient cannot be greater than 7, I wonder how this error will be resolved.
Re: GRADUATED FOUNDATIONS hello You must select the panels that you have entered for the basic grading or that you think will not affect the calculation of the R coefficient and select the sub-basement curtain option from the properties menu. Best regards.
intermediate wall drawing I'm a Construction Technician I just met with İdecad, I'm practicing with the demo version of idecad 6, how can I place partition walls that do not pass through beams and axles at the desired distance with the draw wall command, I cannot use the offset command, thank you for the help in this work.
Re: GRADUAL BASICS Hello, You can do the procedure using various methods. You can define a temporary axis passing through that point. You can use local point definition. Parallel reference can be useful for you. If you haven't watched it, I suggest you watch our training videos. Static:
Architecture:
Re: STAGED FOUNDATIONS
"Levent Özpak":3rp38a1y" said:
To create a foundation at a different level under the elevator shaft, after defining your raft floor, create a space under the elevator perimeter curtains with the "slab gap" command. Create a closed area with the edge of the raft slab at this place you defined. Place a new raft slab in this closed area. Set the level by entering the properties of the raft slab. Calculation axes and working distances of the raft slabs can be arranged as in the sample project.
You defined it as 2 axles in the horizontal direction and 2 axles in the vertical direction, shouldn't there be 3 axles each in the horizontal and vertical directions?
Re: GRADUATE FOUNDATIONS
"Reform Group":13yuqipt" said:
"Levent Özpak":13yuqipt" said:
To create a foundation at a different level under the elevator shaft, after defining your raft slab, under the elevator perimeter curtains " Create a space with the "tile gap" command. Then create a closed area with the edge of the raft slab on this place where you define a gap. Place a new raft floor in this enclosed space. Set the level by entering the raft flooring properties. Calculation axes and working distances of raft slabs can be arranged as in the sample project.
In the sample drawing you made, Mr. Levent, you defined the foundation as 2 axes in the horizontal direction and 2 axes in the vertical direction. Shouldn't there be 3 axles in the horizontal and vertical directions? Sincerely.
Dear Reform Group, In the version to which the project was added, the reinforcement axles did not see the slab gaps, so this definition was made. As you said, in the elevator shaft.cde project, it would be more appropriate in terms of application and quantity to define 1 more calculation axis between the 2-4 and BC axes and arrange the working distances accordingly. There is no change in the analysis results.
