Gives negative results on the raft
MüHenDiS
Hello, since the project is adjacent to two sides, the diameter was complied with and the structure is not rigid, so the analysis was done in a semi-rigid way, but it gives negative results even in 80 or even 90 rafts, so I wanted to make a rafter with beams, but it does not throw the foundation beam on the right and left facades. What is the solution? would you recommend.. can you help me, thanks in advance.
radie Temel Although I could not delete all floors and leave only the basement, its rarity exceeds 4 MB. Could you help me to upload the file?
Re: raft foundation Rare the project. After compressing the file and uploading it to s9.dosya.tc/, you can write the link here. If you save the model in 7 format, more people can view it.
